Configures the LLDP port to advertise or not advertise a requested conservation level. By default, the requested conservation value on this proprietary LLDP TLV is 0, which is no power conservation. This LLDP TLV is sent out only on PoE-capable Ethernet ports.
all | Specifies all ports on the switch. |
port_list | Specifies one or more ports or slots and ports. |
advertise | Specifies to send the information to neighbors. |
no-advertise | Specifies not to send the information to neighbors. |
No advertise.
The switch sends this proprietary LLDP TLV to request a PD to go into a certain power conservation level or request the PD to go to the maximum conservation level. This LLDP TLV is transmitted only on PoE-capable ports.
When configured to advertise, the switch sends this TLV with a requested conservation power level of 0, which requests no power conservation. To temporarily change this conservation level, use the SNMP lldpXAvExLocPortXPoEPSEPortReqLevel object to set a new value; the reconfigured value is not saved over a reboot. (This SNMP object can be set from 0 to 243 or 255.)
The following command configures all ports to advertise the currently requested conservation level to neighbors:
configure lldp ports all advertise vendor-specific avaya-extreme poe-conservation-request
This command was first available in ExtremeXOS 11.5.
